Geforce GT 640 OC 75W TDP problem
mayafree
Dear Tom's Hardware,
I would like to buy a Gigabyte GT 640 OC 2GB DDR5 PCI-X 3.0 videocard with 75W TDP! There is no power connector on it!!!
IT IS NOT for game! I buy this because of CUDA cores.
Adobe Photoshop and video editing...
My motherboard is MSI G41M-P28.
It has PCI-X 1.1 slot with max. 75W TDP!!!
Questions:
1., Can my motherboard PCI-X v1.1 slot handle this videocard with maximum TDP or not?
Problem is not with the Power Supply Unit but with the motherboard's PCI-X slot!
USUALLY these entry level video cards power consumption is 30-65W max.
And the PCI-X v1.1 slot WITHOUT an extra power connector can handle max. 75W TDP only!!!
BUT THIS CARD NEEDS THE MAXIMUM UPPER LIMIT when it is on FULL LOAD!
IS IT SAFE OR NOT? I don't want the slot to get overheated...
2., If I buy a motherboard with PCI-X 2.0 slot, THAT can handle 150W without an extra power connector.
IS IT TRUE OR NOT?
Thanks in advance!
I know ATI would be BETTER in price and speed! ANYWAY it is DDR5!
But I forget to mention that I buy this card because of CUDA cores!!!
Adobe Photoshop and video editing. SO NVIDIA is better for this.
BUT
If I would like to play games then ATI WOULD BE PERFECT!!!
Yeah I saw it also! Strange...
It is TRUE original GIGABYTE! And only available in a few computer shop. :??:
It seems like it is DDR3 not DDR5, google it and it comes back with OP's posts on techreport, overclock.net and toms. Also some 'other websites', seems that they have just put in the wrong details.
The part number on these websites goes to Gigabyte with DDR3.
i dont know about you, but last year i bought this GT640 OC thing. problematic.
suddenly it takes 10 times longer to enter OS. i cannot enter my bios as well (and my motherboard doesnt have onboard vga). sometimes my computer works funny and doesn't detect some of components (e.g. dvd drive, few usb slots, etc).
thank you panopticon! apparently the solution was simply upgrading the bios LOL
I just learned that i can upgrade bios from running windows -_-" now i can enter the bios again after update, yay!
