GeForce GTX 760 2GB OC Windforce Edition Problems With Under Performing and FPS
Eatr61
35
Hello Comunnity!
First of all, sorry for my English, I'm Spanish and my English isn't very good, I will try to do my best to explain my problems and writte all the things clears for your understanding.
I have some "stupid" problem that I can't understand with my GeForce GTX 760 2GB OC Windforce...
The graphic card usually works fine and do his job well but somedays is breaking my patience.
Without reason, the card works but don't match with the performance all the people have with this Graphic Card, playing all kind of games like "Heroes of the Storm" - "Far Cry 3" - "Dishonored" - "Plants vs Zombies" - "The Witcher 2" - "Battlefield 3" - and so much more with max settings with low FPS and minimums frames.
This happend actually without touch anything of the Hardware and Software, from one day to another, the GTX 760 don't do his job properly and I try to search explanations and possibles causes and still don't found it.
BenchMarks with the Problem
Heaven Results:http://puu.sh/hLC68/0f9ded7753.png
Valley Results:http://puu.sh/hLCdL/4782806d1c.jpg
I will show you my Setup:
- CPU: Intel Core i7 - 2700K - 3.5 GHz
- Motherboard: ASRock Z68 Pro3 Gen3
- RAM: Ripjaws X DDR3 1600 PC3-12800 16GB 2x8
- Graphic Card: GeForce GTX 760 2GB OC WindForce
- Power Supply: Cooler Master GX-Lite 700W
- Ventilation: 2 Fans.
- Software: Windows 7 - 64 Bits
- Drivers: 350.12 NVIDIA.
Here are some pics of my System and Setup with performing Issues and Details
My BIOS Details
Main: https://cloudup.com/cEAiRgAIBej
OC Tweaker - Voltage Control: https://cloudup.com/c_J3hxvZoPZ
OC Tweaker - CPU Control and Settings: https://cloudup.com/cc0G8PQcHRc
Monitor: https://cloudup.com/cXhuFW86WBc
Video Inside My Computer and Open Case
Hardware working:https://cloudup.com/cbVxHW_BTVr
I try all kind of things like reinstalling Drivers, cleaning components, uninstalling programs and drivers from others categories... And the problem persist.
Do you have any idea of what happens?
Feels like a strange problems because somedays all the things works fine and others the games suffers from bad performing.
I don't know what to do right now... I don't want to waste money in a Cooler if the problem is from the Motherboard or CPU, and buying another cooler and put in there without working can make get a little bit sad with the computer in general because I don't have any idea of what can be happens...
Because I'm a Computer Technician and this case in particular is destroying me.
More stadistics about the Heat and PC Performance with CPUID Hardware Monitor Pro:
http://puu.sh/hMLcN/e7909afbc2.png
Something strange?
Seems like a usually recommendations in this forum, is one of the best cooler quality/price out there in the market...
How about this Cooler? http://www.pccomponentes.com/enermax_ets_t40_t_b_silence.html I read is near or better than the Hyper 212
Install msi afterburner, turn on cpu temp monitoring in the OSD, play a game.
Post back with max temps.
cpu temps seem to be the issue and you are showing gpu temps...
Ups thats true, sorry... Well I mark your response like "Solution" can I make it back to the normal state?
I'm new in this forums so I don't know exactly how it works all the system and options, sorry for make you work more...
BTW I can't upload an profile pic - avatar, always send me a 505 error even with 100x100 or 90x90 px.
Here are the new screenshot about the CPU Temp: https://cloudup.com/chvGY7RhD5Y
The other day I was desfragmentation my HDD and uninstalling trash with software I don't use... But now I remember a CPU upgrade driver instalation or something like that, but the problem was before that desfragmentation and upgrade of drivers if I don't remember bad.
If Possible I would try a clean install(just windows, drivers and a game to test) to rule out a software issue, so we know if we are dealing with a hardware or software problem.
Right now is hard for me to do it but I will try it...
Seems like the CPU is going well and works fine, just the BIOS showing bad information._
The Graphic Card is working, right? Maybe I will try now to do a Benchmark
I was going over the videos and pics you posted to see if I missed anything obvious...
But then it hit me after watching one of your videos:
What is the make and model of your power supply?
First of all, sorry for the delay in the answer, I was busy this two days...
The Power Supply is an "Cooler Master GX-Lite 700W"
http://www.coolermaster.com/service/support/model/RS-700-ASAB/
And in this days, the problem still alive and without any kind of change.
Okey, recently news... I upgrade my BIOS to the last versions and apparently, now the BIOS show me the real temperature and heat...
Some picture here: https://cloudup.com/cAu9XbrBNSB
Anyways, with this move, Windows detect my OS like a false and illegal product, and the real problem about the FPS still there.
Today I was ready to format my computer...
And even doing it, the problem is the same and persist, I don't have any idea of what can even happens...
Right now I don't have another Graphic Card and another computer case...
The only thing or GPU I have is the Motherboard Integrated Graphic....
I was thinking in change my HDMI but I doubt that will work and show us something new about the issue.
PD: And touching and trying this with the BIOS results in give me a 92.0º C when I was all this time at 53º C CPU.
The Graphic Card was broken from the start, was a manufacturing defect and thats all... I send it to guarantee and they will send me another GPU with the same value so I have doubts now...
What GPU do you recommend? I doubt about this...
Gigabyte Geforce GTX 960 Gaming G1 Windforce 2GB RAM:
http://www.pccomponentes.com/gigabyte_geforce_gtx_960_gaming_g1_windforce_oc_2gb_gddr5.html
Sapphire R9 280X Vapor-X Tri-X 3 GB RAM:
http://www.pccomponentes.com/sapphire_r9_280x_vapor_x_tri_x_std_3gb_gddr5_reacondicionado.html
