GeForce GTX960 4GB or Radeon R7 370 4GB
Filip9
Commendable
May 7, 2016
23
I plan to make my own PC, got list of most optimal parts but my only doubt is which graphic card should i buy?
Radeon is around 40 euros cheaper, but i don't mind spending that money. Main difference is that GTX is 128 bit while R7 is 256, they work at same speed and similar Hz. What would you suggest to me?
you want CUDA then
gtx 960
the gtx 960 is on a whole higher level, performance wise it compares well to a r9 380
straight looking at core speed and bus size is not smart on completely different architectures, its meaningless
I asked in store and they don't have it in market but they told me i can order and they get it in 2 days, but now which one should i get?
all are ASUS but should it be nVidia gtx960 R9 380 or R9 380x, first 2 cost pretty much same and 380x is is just 30 euros higher because it is on sale, should i get 380x? I mostly need graphic for some games and video editing.
R9 380 is same as gtx 960 both 4GB, 300-400 euros, and 380x is just 30euros higher because they have sale, is 380x best option? I play games but i m more interested in video editing, and not sure if all radeon's work good with Adobe After Effects and Premiere pro(on my older PC it didn't read graphic at all)
you want CUDA then
gtx 960
Thanks for help
