Even with a 50% power drop, its still well over 200W..... Vast majority of laptops do not have such cooling capacity.... Anyone that does will have the size and weight of a desktop instead. I guess the power supply has to be at least 400W and would be huge....
I was just pointing out it was possible to do not weather it was a good idea.
Comparing broadly the desktop/laptop version of each card 3060 is a bout 10% faster, 3070 about 40% faster and the 3080 about 60% faster.
Could not find anything for the 3090 way to much power.
If it scale like that a 4090 in a laptop is going to be so cut down and power restricted as to be only good in terms of marketing.
Looking at the power and assuming that 40% cut down die and 175 would scaling that up laptop>desktop we get about 437.5w (which is less that a 4090 desktop card of 422w)
Or we go with 70% power (drops desktop power from 422 to 329 score drops from 123,49 to 117,08 about 5%) the die only needs to be cut down to 55%
If we go down to 60% power(or 284w) the die would only need to be cut down to about 60%. This could have about 54% of the desktop 4090 performance
All the way down to 50% ( 234w) and the die cut down is 75% and this could be around 60% of the desktop part.
While the 50 and 60 power limit end up around the nearly the same assuming my assumption are right the core count of the 50% reduction would be higher and Nvidia does have a history of hiding the power of the GPU on mobile parts. That core count is going to be in big number the power in the small print.
