GELID Gamer Wing 12 PL as cpu fan ?
H3llF1re1000
164
can i use GELID Gamer Wing 12 PL fan as the cpu fan with the 212 evo ?? the fan has a pwm connector so i guess it should work but ill still ask to be 100% sure :)
well i heard someone said if i use a 3pin fan as the cpu cooler it will say error he said
but the fan i want to replace it with only has 1,200rpm.. i was going to go with push and pull config but idk if 1,200rpm is recommended/good enough with the 212 evo
