Question General Nzxt H200 questions!
THEmaged
36
hello everyone, i've been recently researching some components for a new PC build and I'm currently looking at the Nzxt H200 for portability and the fact that its a mini ITX but im wondering if i can actually fit the graphics card i want its the RTX 2080 by evga ill leave the link down below if you want to check it out
here are the current specs i want to fit inside this thing:
Processor
: intel i7-9700k
Graphics Card: EVGA RTX 2080 (maybe the 2080 ti)
Motherboard: ASRock Motherboard Z390 Phantom Gaming-ITX/AC
CPU Cooler: Nzxt Kraken X52
Storage: 250Nvme M.2 / 2x Sandisk 1tb SSD
RAM: Corsair Vengeance RBG Pro 2x8 16gb
PSU: EVGA 750 watt GQ 80+ gold
https://www.amazon.com/EVGA-GeForce...55&s=gateway&sprefix=rtx+,aps,235&sr=8-4&th=1
After putting everything, except your storage since I couldn't pin point which exact one you chose, on pcpartpicker it shows that there are no real compatibility issues with the case and either video card. Though it does give a compatibility note:
  • Note:Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
Hope this helps.
Here are the links
2080: https://pcpartpicker.com/list/Hjhx8Y
2080 TI: https://pcpartpicker.com/list/jnCvBb
Hope this helps.
Here are the links
oh wow okay i see thank you for taking the time to do this for me im also looking for diffrent possibilites and changing the cpu
and btw do you know if the Kraken x52 will be a good cooler for an i9 9900k? or give me some cooler recommendations maybe? i chose the kraken cause its the prettiest cooler XDDD
