Hi guys, the question hasn't been asked before, but close answers are given but always against each other.
I'm about to buy this desktop but I need to know if the things people are saying here are true since I discovered people here generally are misusing the term SFF and MT.
To be clear I want to buy the mt version 6300 HP Compaq pro.
This seems to be the spec sheet.
https://support.hp.com/us-en/document/c03382665
First : there are people complaining about the size of the GPU they use a small GPU in order to not touch the fan of the cpu. However if I take a look at the spec sheet the size seems to be mismatching only 0.3 inch..
I guess the touching the fan of the cpu might be only applicable for SSF?
I'd like to know this before buying a video card..
Secondly: Also the PSU might be not a sufficient supply for let's say a 1080 GTX.
However the HP power supply isn't changeable according to people here, well I'd like to know what your opinion is on that.
The thing is I found this website where two solutions are proposed by different people so I guess it is possible? Maybe you guys could tell me if it could be true..
https://linustechtips.com/main/topic/902466-how-to-upgrade-hp-pro-6300-power-supply-fix/
Thanks
EDIT: I guess 90% sure that I figured out the size of the 6300 mt is really really small to put a big graphics card in it..
So that brings me to another question what is a good pre built PC like for instance HP/DELL OPTIPLEX 3020/7010. I like to have a i5- 3470 in it at least and it would be nice if a full GPU could fit and also PSU could be changed easily 😉
Thanks !
Thanks
Thanks !
