General question about jumpers
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a very general question about jumpers. In the handbook of my A7N8X-X
every PIN is described exactly. For example, for the speaker connector it
exactly says which PIN is +5V, which ones are Ground and which one is
Speaker. However, on the 4-PIN connector cable one this information is not
given. Does is _not_ make any difference which way I connect the cable;
after all, there are two possibilities? If the way I connect the cable _is_
important, how do I know how to do it (except for trial and error)?
Thanks,
Matthias
Der Andere wrote:
> Ok, but I have this issue in most of the jumpers I have connected, the
Can I point out to you that when you connect a cable to the motherboard, you
are connecting a cable to a motherboard header. Jumpers are used to short
two (or more) pins together. Yes, the connectors are similar, but the whole
idea is different.
> speakers was only an example.
Technically directional, but practically either way will be fine.
> I also have the Power LED,
Directional, since it's a Diode.
> the ATX Power Switch, the Reset Switch
Both momentary switches... either direction is fine it's the (short)
connection you're looking for.
> and a harddisk connector.
Again, and LED (diode) and thus directional. If you plug a diode in the
wrong way around, it won't work. You won't break it by doing this, it's
completely safe to try a hit and miss approach. (connecting the wrong pins
together is a completely different thing altogether and could break things).
> My computer sometimes
> simply crashes (resets itself, tries to reboot and then halts). I wondered
> whether this could be due to some jumpers connected in a wrong way.
Maybe. But cables connected the wrong way around is unlikely to cause you
stability problems.
I would suggest checking your temperatures, if they are ok, replace your PSU
with a better one.
> I know
> there could be many other reasons for this occuring, but I really tried
> many other things before and just wasn't sure about that jumper-issue. A
> friend of mine told me that his computer was not stable until he changed
> (rotated 180 degrees) some jumpers.
Thats ridiculous. Thats like saying my speakers sound better when I use the
wires the other way round. It might be true, but it will not be a direct
result of turning the jumper around, it will be an indirect result of
correcting a bad connection either on the jumper or something else.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
> idea is different.
> stability problems.
> with a better one.
>>I know
> Ben
Or... my stereo speakers sound better when I listen to the right speaker
with my left ear and the left speaker with my right ear
In article <sTOtc.15351$L.12555@news-server.bigpond.net.au>, Legend
<ISO-teric@ISOLated.com> writes
>Ben Pope wrote:
>> Der Andere wrote:
(snip snip)
>>>I know
>> Ben
I can confirm that this jumper is very uncomfortable, and looks silly,
when I turn it round.
Roger Hunt
Ben
