Question Ghosting when using motion blur reduction
So I would start out with Normal settings and then try gaming. If you experience no visual problems then you are fine. If you do have a visual problem then address it. Trying to find a cure for a problem you do not have will confuse things. Motion blur setting is not for fixing Ghosting. They are two different things.
Dec 26, 2022
14
tried normal and vrr modes, no ghosting but blur image on fast motion
