[SOLVED] Gibabyte Aorus Master B550 bios
50bmg
906
I currently have bios F3 from the factory. I see the bios's are up to F13a. F11 is no longer available.
Anyone recently update to F12 or F13a? Any issues.
edit to add specs
Gigabyte B550 AORUS MASTER F3 F12 bios | Ryzen 5 3600 4.2Ghz | Thermaltake 240mm water 3.0 | XFX 5700 6G | Patriot PVS416G400C9K 32Gb DDR 4000Mhz 1.35v 19-19-19-39 | 1Tb WD Black M2 NVME | 500Gb Crucial M2 NVME | Thermaltake 850w Toughpower 72A 12v rail | Fractal Design 7 case | Win 10 Pro 64
Sig space specs can and will change over time. When that does happen this thread and it's relevant solutions will become moot to the person in the same boat as you're in right now. Which is why you're asked to include the specs to your build in question into your thread's body.
As for your BIOS question, since you're on BIOS version F3 and your motherboard manufacturer's support site(here) has F13a as the latest, you're suggested to update your BIOS in this sequence; F4>F5>F6>F10>F12>F13a(following instructions made in the notes)
