[SOLVED] Gigabyte 78LMT-USB3 R2 problem
May 20, 2020
Hi All,
I am currently trying to build a simple pc for my wife,
I purchased the
Gigabyte 78LMT-USB3 R2 mobo,
AMD FX 8350 Black Edition "Vishera" CPU,
a 1050ti GPU,
corsair tx650M power unit and
1x8gb Kingston ddr3 ram.
I have built the pc the same way I have done every other one before, power up, all led's go on, all fans turn but nothing to the display, via the motherboard or the GPU.
has anyone else come across this? is probably something completely stupid that I'm not seeing.
I am so close to lobbing it all in the bin and starting again.
I hope you wise and worthy mages can help me out.
Thanks for reading.
PG
Try different ram or different slot, remove the battery and reset the bios, also remove the GPU, and try to get screen first without 1050ti, after all is good and working you can try and run with it.
