Gigabyte 970A-D3P memory problem??
Dmt317
126
My bios says that my memory is running at 1334 mhz and I have 1600 mhz ram? What is causing this and how do I fix it. My bios is up to date with the f5 flash.
Hi there, i had the same problem.
First go to bios,
Then, Advanced Frenquency Settings,
Then look for ''Extreme Memory Profile(X.M.P.)'' and set it to Profile 1.
Then save and exit and it should now be to 1600MHz.
This is quite common, You can change the speed back up to 1600MHz in bios and it is safe and won't damage your memory module. If you wish to overclcok it back up to speed just put the volts to 1.5V and tweak the speed to 1600MHz. That should work fine and this problem is quite common, after that the speed should be back to 1600MHz.
What set of DRAM do you have, if it's the rig in your sig, see if the advanced section of the BIOS and look for EOCP or DOCP if there enable it and select 1600, if not manually set freq to 1600, DRAM timings to spec for the set and set DRAM voltage manually to 1.5
I guess the multiplier was like 6.67 and i tweaked it to 8 and it said that would be 1600mhz and saved and exited and then it said failure to boot so i went back in and changed it to 1334 again
First go to bios,
I have the same problem but can not find the'' Extreme Memory Profile (XMP)'' option
In my ga-970th-D3P does not have this option.
What do I do?
Bios is the latest version already.
