Hi everyone,
I'm about to build myself a new $5000 video editing system. I've done quite some research on CPU/RAM/GPU/SSD(M2) cores, speeds, latency etc., but for now I'm stuck on cooling the graphics card.
System: https://pcpartpicker.com/list/HwGKvV
Initially I'm planning on buying the Gigabyte Aorus GeForce GTX 1080Ti Xtreme Edition 11G. However, the Gigabyte AORUS GeForce GTX 1080 Ti Waterforce WB Xtreme Edition 11G also sound very interesting. It's a little more expensive, but it's more quiet, it's smaller and it's water cooled, right?
There lies my question:
How does this Waterforce WB Xtreme Edition gets cooled? I know it has a connection on the side to connect two tubes and on the bottom of the card it has a heat sink, but my knowledge on water cooling is too little to find anything useful on Google (except for normal water coolers, but they can't fit the side tube connector thing (the water block?).
Does this card require a complete water cooled system with a pump and everything? Does'nt the card need any type of cooler at all? Does it need to get cooled through the heat sink, using a normal water cooler (like the Thermaltake I already have for the CPU)?
I know this probably is a basic question, but I couldn't really find anything useful.
Thanks!
Thanks!
