Spec : Processor : i-7700k
GPU : Gigabyte Aorus GTX 1060 6gb
RAM : Gskill Ripjaws v ( 3200ish ) 16gb
Mobo : Gigabyte Z270x - UD 5
Hello,
First of all i'm a computer illiterate.
So i've been getting this problem since yesterday , it happens after i restart my Computer
I was playing skyrim , with some graphic mods , and i'm pretty sure even with the Mods , i would still get constant 60fps if capped , because i tried running Witcher 3 in the background with max settings , and play Deus Ex : Mankind Divided , still get 60s ( sometimes around 49s on crowded area ) , here's the issue
On Skyrim - I started to lag on cities , such as Whiterun and Dawnstar which is something that couldn't happen , and the issues are just... just weird , since i NEVER ever lagged out playing Skyrim , and here's 1 more , Everytime i go AFK , the FPS goes down , for an example
i'm getting constant 60 fps , afk for 2 minutes , goes down to 45 , so i tried to go AFK for like half an hour , guess what , even on a cave where there's only few things to render , i'm getting less than 10 fps , and it's constant , i tried to walk around , ALT - Tab and stuff , still getting 10fps , so i have to restart the game , everytime i went afk
and now i'm only getting 50s fps on Witcher 3
another issue i discovered is with Injustice 2 , i almost gets instant loading whenever i switch character / switch items ( gears ) and now everytime i switch character , the character renders , Right ? and i got 4fps and the load time is just way longer
What's happening on my pc , help :\
note : i put my pc settings on full power , and the gpu has a light in it , i set it as "Monitoring" on GPU software , so i can know GPU Usage
Green ( Low ) to Red ( Very High ) , usually it runs on light yellow to Orange ( only happens when i tries to run 2 games at once ) , now it's ALWAYS on green , means it chooses to lag instead of using more power.... help please 🙁
Hello,
