Question Gigabyte Aorus Xtreme BIOS UEFI problem ?
Walt_S
4
I updated the BIOS on the Aorus Xtreme v1.1 to the latest BIOS version. When I went to enter the UEFI after the update (via pressing DEL), the monitor lost it's source. I switched from DP 1.4 to HDMI, tried different cables, different monitors, made sure everything was up to date, reflashed the BIOS - no change. I saved the BIOS I had before the update and was able to revert back to it. Since doing so, I'm able to get back into the UEFI. Any ideas?
BTW - After POST, I am able to get to the Boot Order menu (via F12) and the Q-Flash (Gigabyte BIOS utility) menu (via END).
- EVGA RTX 3090 FTW3, Ryzen 9 5950x - if that helps.
TIA
What BIOS version did you work your way up from? Side note, did you get the PCB revision of your motherboard correct? There seems to be a Rev 1.0, 1.1, 1.2 and a 2.0 of the motherboard.
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list them like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
including any parts that might've been upgraded or changed. Include the age of the PSU apart from it's make and model.
OK. Sorry about that.
CPU: Ryzen 9 5950x
Motherboard: Gigabyte x570 Aorus Xtreme v1.1
Ram: GSkill (Samsung chip) DDR4-3600C16 (4 DIMMs of 16GB - 64GB total)
SSD/HDD: OS SSD is Sabrent Rocket 4 plus 2TB
GPU: EVGA RTX 3090 FTW3
PSU: Corsair AX1000
Chassis: Phanteks Eclipse P500A
OS: Windows 10 64
Monitor: LG 38GL950G
No new components since the issue began.
