[SOLVED] GIGABYTE B550 aorus elite v2 and my ryzen 9 5900x did not work
5
I buy a GIGABYTE B550 aorus elite v2 and my ryzen 9 5900x did not work. Try with a ryzen 5 3600, work fine. I update de lastest bios and nothing, no video with the ryzen 9 5900x.
After installing the 5900X, did you manually reset the motherboard BIOS before powering on?
Which revision is your motherboard?
https://www.gigabyte.com/Motherboard/B550-AORUS-ELITE-V2-rev-10-11#kf
Motherboard revision is 1.5
I install the cpu and no video comes up. Reset the bios, the same thing. Put a ryzen 5 3600 to test and the video comes up, and let me in into bios config. Before board let me in into the bios, put a message that i have to reset the TPM. I say yes.
Double check that both your 8-pin and 24-pin power cables are firmly attached to the motherboard.
It is also possible you have a defective CPU. Wouldn't be the first time that happened. From where did you purchase it?
I already have it working in a alienware r10 with a x570 motherboard. I Just put it out and mount in the other board.
