Need to reset the cmos of the gigabyte b550i tried the jumper but no luck.
The battery is behind the rear io shield which is brilliantly located underneath the plastic cover at the back. Removed the 4 screws attaching it in however can’t seem to get it to come free? presume there is a knack to it? Rear IO shield is a pre installed one and is encased
