Gigabyte GA-970A-UD3 Socket AM3+ 970 ATX AMD Motherboard Help Please!!
michael06
136
Hello yall I just built me a New Gaming Computer on Sat & im having trouble with some things here is the spec of my PC
Gigabyte 970A-UD3 Socket AM3+ 970 atx amd motherboard
Amd Phenom II X4 840 Quad-core Processor 3.2Ghz Overclock it to 3.8ghz
Corsair
Hydro Series H70 High Performance Water CPU Cooler
Patriot G Series Sector 5 4Gb DDR3-1600mhz
Timing 8-9-8-24
EVGA Nvidia GeForce GTX 560 Superclocked 1GB GDDR5 Graphic Card
Hitachi 500Gb 7200rpm 16MB Cache Sata 3.0Gb/s 3.5 Internal
hard drive
Ocz ModXStream Pro 700Watt ATX Power Supply
Antec Gaming Case W/ Blue Neon Lights
LG 22x Dvd Burner+Dual Layer
I got everything set up & im looking at the amd overdrive & I look into the GPu Status & my graphic card is not operating on amd overdrive!! I open up a different program called Cpu-id & my graphic card is showing it working & the clock setting is at 0mhz & Shader Clock 0mhz I need help setting it up & try to go into bios to find the setting of it but cant find it no where!! Also on my motherboard my usb keyboard keeps shutting off & on & I go to look on Amd Overdrive the Diagram & my PCIe is not showing also my other usb is not showing on the diagram!! Can someone help me out I would post pic but i dont see how to attach them or even try to show yall what problems im having!!
Ya I see the pcie 1.1 with the question mark!! The thing tough is that I downloaded the new driver for the graphic card & i use the gigabyte driveragent & its saying the driver for the graphic card is old... everything below saying they are old also I already updated bios but dont know what settings to change if you can help me out? here the things that saying that old & not showing my diagram
IDe ata/atapi controllers
standard dual channel pci ide controller old
Disconnected Devices
Generic PnP Monitor Old
Hid- Compliant Mouse Old
Usb Input Device Old
I dont know why all this says old? everything else is check green meaning that the driver or something is good!! what can I do?
Ya I have done that a couple times after I updated bios & everything else lol im just bout to throw this *** out the window it shows there a 8 errors & cant fix the damn thing some how idk whats going on with it? I had the computer overclock to 3.8ghz now its suppose to be 3.2ghz now I reset the bios back to normal not sure if im overlcoking it right but it showed that it worked & i let my computer run for awhile then it just goes up & down the 3.8ghz so now its back at 3.2ghz but its showing 3.22ghz suppose to b 3.2!!
I dont have the Amd Chipset installed i thought that was only for FX processor? The one i downloaded last night is a ati catalyst verison 03.00.0765!! Do I install this for the amd phenom 2 x4 processor?
oh ya So do I install that for the Nvidia graphic card? is there a chipset driver im suppose to get or? the one i downloaded is a motherboard driver amd chipset 8 series win 7 that the catalyst driver
oh ya well i dont have any ati catalyst drivers installed only the gtx 560 nvidia graphic but its showing on the gigabyte driveragent that the following things are old see here a list
Nvidia Geforce gtx 560 graphic old
I dont know why all this says old? everything else is check green meaning that the driver good but idk bout to throw this *** outside lol
i will give you something else try this and it's free working good just use the translator http://www.touslesdrivers.com/ install the plugin ma config and then get back to tout les drivers.com and auto detect you will be suprise that this site found for driver missing
Hey bud can you send me the link what to download i dont know what to download? I already have a driveragent already installed i can auto detect that & it tells me what the problems Is then when i try to download the driver it goes to another page saying buy the software i dont wanna do that!! if you can send me a like to my email Raildawg2006@yahoo.com I would appreicate it
also remove drive agent
