Gigabyte GA-970A-UD3 Socket AM3+ 970 ATX AMD Motherboard Help Please!!
michael06
136
Hello yall I just built me a New Gaming Computer on Sat & im having trouble with some things here is the spec of my PC
Gigabyte 970A-UD3 Socket AM3+ 970 atx amd motherboard
Amd Phenom II X4 840 Quad-core Processor 3.2Ghz Overclock it to 3.8ghz
Corsair
Hydro Series H70 High Performance Water CPU Cooler
Patriot G Series Sector 5 4Gb DDR3-1600mhz
Timing 8-9-8-24
EVGA Nvidia GeForce GTX 560 Superclocked 1GB GDDR5 Graphic Card
Hitachi 500Gb 7200rpm 16MB Cache Sata 3.0Gb/s 3.5 Internal
hard drive
Ocz ModXStream Pro 700Watt ATX Power Supply
Antec Gaming Case W/ Blue Neon Lights
LG 22x Dvd Burner+Dual Layer
I got everything set up & im looking at the amd overdrive & I look into the GPu Status & my graphic card is not operating on amd overdrive!! I open up a different program called Cpu-id & my graphic card is showing it working & the clock setting is at 0mhz & Shader Clock 0mhz I need help setting it up & try to go into bios to find the setting of it but cant find it no where!! Also on my motherboard my usb keyboard keeps shutting off & on & I go to look on Amd Overdrive the Diagram & my PCIe is not showing also my other usb is not showing on the diagram!! Can someone help me out I would post pic but i dont see how to attach them or even try to show yall what problems im having!!
hey ya bud i was just surfing around on the internet had my computer running for bout 20mins then had another blue screen why is that? Do i just go back to the memory settings & change it back to auto cause i had the computer running all last night & this morning now its blue screening me when i try change the settings!! I think its that idk
Ya Def got it Fix but I had a different forum I was trying to Overclock my computer & someone help me set everything the way it was suppose to be set at now im not having any problems at all But thanks for everything buddy!!
