Hi,
*I understand that this card has an idle fan feature (fan off when temp < 60° C)
I've got a Gigabyte GTX 1060 6gb card with an 8-pin power connector. I plugged in a 6pin + 2pin to fulfill the power requirement.
It runs games like Apex Legends fine under load @ ~83° C (hot) with an external fan blowing into the case. The fans aren't spinning under load nor do they spin once temp > 60° C.
My troubleshooting:
Please help me find a solution:
Should I start the RMA process, or is there something I may be missing?
Thank you!
My troubleshooting:
- Fans do not spin on startup (like other owners reported).
- Used DDU to uninstall all current drivers and restarted.
- Reinstalled Nvidia drivers (430.86 Win 10 64 bit).
- Tested under load - still not spinning.
- Installed MSI afterburner & enabled manual fan speed - still not spinning.
Thank you!
