Gigabyte GTX 1080ti power connector confusion
kubakakauko
6
Hey, I recently upgraded my GPU from AMD R9 290x 8GB to GTX 1080ti and me noticed an issue that confused me a lot.
So I have just received my GPU about an hour ago and without much thinking, I started taking my computer apart. I took my old graphics card out and I slid new GTX inside when I noticed that the GTX 1080 REQUIRES DIFFERENT AMOUNT OF PINS.
I don't even know how to check if 1080 will work with my old power supply 🙁 and I'm scared to try
LINK TO MY OLD GPU: https://www.techpowerup.com/gpudb/b2843/sapphire-vapor-x-r9-290x-8-gb
POWER SUPPLY AND PINS: https://imgur.com/a/AZukkZj
Guys, I don't really know what kind of power supply I have but I know that it has 2x 6+2 pins
So I would be very happy if you could help me figure out how to plug GTX by looking at my old card's specs :)
THANKS
(Sorry for bad English)
That's a golden green hx gold.
Either a 650 or 750w if it's has twin 6+2 pins.
Not going to be an issue with 1080ti at all.
Crack on & use it.
6+2 to one connector , 6 to the other & leave the 2 pin hanging.
hi i upgraded from the 290x which used 2x 6+2 pins and also got the gigabyte 1080ti (aorus model)
my 1080ti wanted 2 x 8 pins so just plugged them all in and worked fine.
What is the exact model of your 1080ti?
also what PSU do you have ?
A GPU that works with a 290x will work with a 1080ti.
You're going to have to look at your old power supply. There are a lot of extremely horrid PSUs that have no business powering an $800 GPU that will have the correct connectors. You'll need to tell us everything you can about the PSU, whether it's telling us the brand written on it and the +12V rail or taking pictures of the whole thing or we can't answer the question.
I'm especially worried you used a power-hungry GPU and then bought an $800 GPU without knowing the PSU you have. That's the computing equivalent of taking pills from an unlabeled container that you find lying around.
1080 ti should use two 8 pins, or maybe a 6 + 8 pin.
and 290x uses 2 8 pins, you want to connect one of your 6+2 pin into the 8 pin, and connect the main 6 pin (from the 6+2 pin) into the 6pin hole. you can leave the +2pin hanging on the side.
thanks for your quick response I took a couple of pictures of the power supply and the pins but I don't think they are going to help much 🙁
Thanks for your fast response :) I took couple pictures of the hardware that you requested because I don't really know the models 🙁. Sorry
I think im a bit confused, you have a psu With 2x 6+2 connectors and a Gfx card with 2 8pin connectors. So effectively they are the same. They only go in one way the same as on your 290x had a 6+2 to make an 8.
On the box, it says that it needs 8pin and one 6 pins with a power greater or equal to 600w.
But just to make sure what power supply I have I sent a ticket to OverclockersUK where I got my pc built. So let's wait until they reply with the model of my PSU
What bothers Me more is if that's a bottom mount Psu & the case has a fan grill on the bottom it is to all intents & purposes upside,down imo.
If it were the right way round you'd clearly see the label on the side.
Exit - if you only have a pair of 6+2 cables it's a 550w model, the 650/750 have 2 pairs of connectors , 2 on each cable.
You are correct i took turned it the other way and the sticker said that its 550 should i put GTX1080ti inside ?
What's the rest of your system ?
I know gigabyte state 600w But the :-* is a very good Psu & is an old precursor to modern dc-dc units (as in it can fulfil near its whole rated wattage on the 12v rail alone)
As long as you're not running 10 drives & a 150w+ cpu it'll manage absolutely fine.
I have I7-4790k
16gb DDR3 ram
2x 2tb HDD set to RAID0
And wifi card that i can take out
