Gigabyte GTX 970 power cables
Ghost24
153
Hi guys!
I've got a question regarding the card above. It needs one 8 pin and one 6 pin power cable. My corsair hx 750 psu didn't come with a 8 pin cable. It is currently connected via two 6 pin cables, and it runs fine, but I would like to connect it properly. The problem is I can't seem to be able to find an 8 pin cable to buy separately, there are only extension cables. And I don't think I should buy a new psu just because of this.
So the question is can I buy this cable anywhere, or is this fine the way it is now?
Thanks for your time.
Yes, that's the way it is connected now. But my concern is that the other end of the 6+2 pin cable, the end that connects to the psu, has only 6 pins not 8. The plastic housing has 8 slots, but only 6 are occupied. Or is this the way every cable is?
