gigabyte motherboard stuck on boot screen after cmos battery removed
testserver
Commendable
Dec 31, 2016
6
hi i need a lil help with this one
so the problem started when i was cleaning my pc and i had to remove the hdd led but when i was finished i put it back where it is but the pc then got stuck on the post screen idling on booting from cd dvd but after that it says disk boot failure please insert system disk and press enter
i thought it was my hard drive but it was fine so i inserted my system disc and it told me to press any key to start xpressrecovery but then my keyboard didnt work
it didnt respond to the boot menu or such
so i went here to find a solution to the keyboard and two topics suggested that i reset cmos and i removed the battery to reset it but the keyboard remained not working
now every time i try running my pc either it works but get stuck in the boot menu or it doesnt work at all
so any help would be appreciated!
