Gigabyte rebate asks for original model/serial # label?
Wlau21
54
How do i get the original model and seral number sticker off the box if it is glued so tightly onto the box? I want this $20 rebate and I know companies try to jip you out of your rebate for every little thing.
Thanks
Cut it out, almost all boxes will just peel the top layer off with the sticker, you don't even need to cut out the whole box under the label. Just cut a bit around the labels, then slowly peel them up using the knife.
It just feel like that's not how it should be done...
