• Our team is working to address issues posting quotes or media to the forums. Please bear with us as we get this sorted out.
Question Gigabyte z490 Vision D problem installing W10
Aug 7, 2020
6
I put together a new pc with a Gigabyte z490 vision d motherboard, I5 10400 CPU and a m2 WD black HD
. I cannot boot the pc from a pendrive to install Windows 10.
When I try to do it, the pc hangs.
Is it a problem with the BIOS setup?
will it be easier to boot from a dvd?
I will appreciate any advice you can give me.
Thanks in advancre and Beste regards
Aug 10, 2020
68
14
Boot from USB is not always enabled in the BIOS settings. If light on USB blinks and then still hangs the pendrive isn't bootable, missing boot files.
Jan 2, 2021
Hi! I know this is a little late but did you manage to solve your problem? How?
I'm having the same issue with b550 vision d.
Aug 7, 2020
6
Hi friend. I already solved it.
You must create a portable USB pendrive with Rufus and boot the PC with it.. Then, install Windows normally.
You can download the Rufus from here:
Good luck!
