[SOLVED] Gigabyte z590, 5 beeps and the VGA LED is lit ?
6
Hi,
I m building a new PC.
My processor is i5-11600k
The motherboard Is gigabyte z590 gaming x
When the PC starts, It beeps 5 times & the VGA LED is lit.
I have not installed a video card because the CPU should have integrated graphics. Is it mandatory to have one?
Thx
5 beeps is console output error on aptio V, link above is for older ami (non uefi) bioses
mine gpu produces 5beeps when tv is turned off during post, but system boots fine
This CPU?
https://www.intel.com/content/www/u...-12m-cache-up-to-4-90-ghz/specifications.html
This motherboard?
https://www.gigabyte.com/Motherboard/Z590-GAMING-X-rev-1x/sp#sp
User Manual:
https://download.gigabyte.com/FileL...x-ax_e.pdf?v=7a08f934cbab820677808065d9dfd83b
As I read the specs motherboard and CPU support integrated graphics. There should be no need for a separate, mandatory GPU.
Paragraph 20, Page 23 covers the Status LED's. Verify that you are reading the LEDs correctly.
Beep codes:
https://www.gigabyte.com/Support/FAQ/816
Verify the beeps you hear: number and length.
Are you able to access BIOS?
This CPU?
This motherboard?
User Manual:
Beep codes:
Thx for your reply.
Yes, the CPU and the motherboard are right as in the links you posted.
Currently I have no display attached, I m waiting for the adapter from dp to DVI.
The manual says that the issue Is related to the vga( the led stay on)
But, In the FAQ 816 seems to be and issue related to the processor (5 short beep)
Who Says the right thing?
"right thing"
No way to know. I expect that you will need to wait for the adapter.
Will the new PC build boot into Safe Mode?
If so then Reliability History and/or Event Viewer may have captured some relevant error codes, etc. regarding previous failures.
Take a look.
"right thing"
Take a look.
Thx for your help, i Will inform you when I wiil receive the adapter
Thx for your reply.
When I Will be able to connect the monitor I Hope that I should see BIOs alerts.
I Will inform you ASAP
Thx for your reply.
Hi, finallly i received the adapter, It works, the display Connection Is mandatory for the First boot.
I see the motherboard messages, I Will proceed setting RAM timings etc
Thx for your help
