Gigabyte Z68 Bios Flash Help...
k@rt
150
5
18,715
Hi All.
I have decided I would like to flash my Z68 mainboards BIOS. Now I know people always say never flash unless you really, really have to. The main reasons I want to flash are that whilst my PC has no fatal problems there are a few smaller issues I have never been able to figure out which I thought could be related to the bios. The other main reason is that my mainboard is running a very, very old BIOS version and as I would also like to update to windows 10 soon I thought a more up to date BIOS could not do any harm and could maybe facilitate performance advantages.
My mainboard is the Z86X-UD4-B3 and it is currently running BIOS version F5!! So far as I am aware this is the oldest BIOS which even exists for this mainboard, it is no longer even listed on Gigabytes site and doesn't even support the oldest versions of Touch Bios.
I have looked at these tutorials and it seems pretty straight forward to do:
https://www.youtube.com/watch?v=lJ_hWeg_wF0
http://www.macbreaker.com/2012/01/how-to-update-your-bios-on-gigabyte.html
However as I want to be 100% sure I make no mistakes I have a couple of questions:
If I format my USB stick to FAT32 and put the BIOS file onto it, do I also need to change the boot order?
So far as I can tell from the tutorials if I use the Q-Flash system (which seems the best way to do things) then there is no need to change the boot order and the USB stick with the will get picked up automatically and my hard drives ignored. Is that correct?
Which BIOS version should I upgrade to? F10 or U1E?
On my mainboards downloads page (http://www.gigabyte.com/products/product-page.aspx?pid=3849#bios) the most recent version is U1E but that seems a little more complicated to upgrade to, and I was wondering if upgrading from such an old BIOS version may mean greater risk. On Gigabytes page it says the following, " When updating from legacy to UEFI, use only the utility attached to your BIOS file"... what exactly do they mean by that? Are they talking about if you are trying to flash from Windows? Or are there other steps involved in the Q-Flash?
It also says I need to remove Smart6, Dynamic Energy Saver, Smart TPM, and Touch BIOS. I know I don't have touch BIOS and so far as I can tell I don't think I have any of the other things either. I assume that if I look carefully through my current BIOS settings and don't see any of these it should be okay, and if I do find one then I just need to make sure it is disabled?
Can anyone tell me what the practical difference is between F10 and UEFI BIOS?
Is there an advantage/disadvantage to having one version over another? If it makes any difference the rest of my system is: Intel i7 2600K, GTX 580 and 16Gb RAM, SSDs for OS and HDDs for files.
Finally is there any other advice, tips or things I should watch out for not covered in the above linked tutorials?
I have made sure I have written down all my current BIOS settings (well taken pics) so I can set-up the new BIOS correctly should all my settings get wiped out. I will make sure I save/backup my current BIOS onto my USB stick using Q-Flash before I try flashing... although at this moment I am not completely sure if something did go wrong how I use that bkup file.
As I said, any suggestions or advice would be great!
Thanks All!
I don't recommend updating to the uEFI BIOS on this board. I have a Z68X-UD3H-B3 and the uEFI BIOS update is buggy and unstable when overclocked. I actually just got sick of it and flashed it back to the most recent non-uEFI bios for the board (which is quite difficult to do). So I'd go F10.
Thanks Quixit! I was thinking that maybe something like that may be the case but it's great to have it confirmed by somebody with first hand experience. I'll definitely go for the F10 version.
Btw, I am correct that there is no Board Revision number to worry about with my mainboard? The only page on Gigabytes site for my mainboard is marked as Z68X-UD4-B3 (rev 1.0) so I assume that means there was only ever one revision of the board and all are covered by the same BIOS.
Thanks again! I actually took my PC completely apart for paste replacement and cleaning and whilst I had to Mobo out to clean behind it I actually found the Revision Number... had never seen before because normally it is covered by a cable :)
I just need to get a brand new USB stick (hopefully tomorrow) and then I will be ready to flash! I am still a little nervous about it because it's my first time, but really looks quite easy. I will take pics of all my current bios settings so that I am sure to get the new settings right...
I will turn my processor OC off before flashing, but do I need to also turn down my RAM frequency? It's not really OC'd, I have it running at 1600Mhz but while back I had a BSOD and my PC/BIOS loaded (I think) the fail-safe defaults and it kicked the RAM frequency back down to 1200Mhz, so I am not sure if 1600Mhz is considered and OC in the BIOS.
