Hi guys,
I am currently failing a little to successfully connect my nine fans on Gigabyte's Z690 Gaming X DDR4 and via the additional Nexus+ 2 fan hub included in the Fractal Meshify 2 case. Six of the fans are shipped with 4 pin heads, and three with 3 pin heads, thus requiring way more fan ports than the Mainboard (fan layout) offers, as long as I don't resort to using Y-splitters. The three 3 pin connectors aren't much of a problem and atm directly connected to the Nexus+ 2 fan hub. I guess the rest of the fans should also be fine and connectable with the help of some PWM extension cables. But now how about the fan hub itself? It has one SATA connection to connect it to a 6 pin to SATA cable connected to the PSU, but also one cable with a 4 pin head. Here's some novice questions ...
And my goodness, instead of including dozens of extra cables, maybe Corsaire should think about adding an extra inch or two of cable length! There's a lot of potential here that's falling by the wayside imo.
Best regards & thanks in advance!
- Can I connect the Nexus+ 2 fan hub to any SYS_FAN port on the Motherboard? I read somewhere the occupied CPU_FAN port would be required?
- Can I connect the Nexus + 2 fan hub to the unoccupied and easily reachable CPU_OPT port? Or are CPU_OPT & CPU_FAN coupled, thus not recommendable?
- Can I use a regular PWM extension cable to connect the CPU_FAN with the reverse Y (2 to 1) 4 pin connector from the CPU cooler? (some extra centimeters to hide cables)
- Any reason in general not to use Y-splitters for fan PWM cabling? Looks probably much better for my build.
