Gigabyte Z97-X Gaming 3 with 4 pin PWM fan
Jan 21, 2019
Hi. I am a bit of a newbie, so sorry if this is really obvious. I just wanted to ask if my motherboard can support this fan: NOCTUA NF-A12X25 PWM
Yes it can.
If you look at the motherboard manual (online) you can see that it has 4 pin fan headers, that means you can use both PWM and DC (3 pin fans).
Just make sure that BIOS fan options are set to be Auto or PWM.
Yes it can.
