Going to build my own computer. Please help.
CompUser08
Commendable
Jan 20, 2017
11
I have successfully installed the power supply in to the 8900. But, I am thinking of building my own computer now instead of buying pre built. I have decided on several CPU's but I am not sure which brand of motherboard to go with.
He is right, Asus,msi, etc but asrock are not too bad really, some as rock are better than big budget range, gigabyte can on occasions give you a headache but overall depending on your budget Asus is prob midrange to go for.
I have chosen my CPU, but I now need a CPU cooler. My CPU is the i7-6950X and the computer case is Fractual Design XL R2. For the motherboard, I am not sure if I should go with the Asus Rampage Edition 10 or the Asus Deluxe 2, in terms of the CPU cooler being quiet and cool and allowing room for the RAM slots and the PCIe slots. I'm leaning towards the Be Quiet Rock Pro 3 CPU but I am not sure if it will be compatible with either of the Asus Motherboards and the XL case.
