O Oracles Reputable May 6, 2014 11 0 4,510 Jul 18, 2014 #1 Any ideas on really good monitors for tri monitor display with a fairly small border? My budget is about 140$ per monitor. (ideal) Also, my graphics card is a GTX 780 SC. That should support it, correct? Thanks.
Solution B B bushbaby1234 Jul 18, 2014 I have 2 of these they look amazing next to each other. they great monitors in general. they are $150 normally but go on sale quite often http://www.newegg.com/Product/Product.aspx?Item=N82E16824009483&cm_re=h236_h236hl-_-24-009-483-_-Product they do NOT have a vesa mount if you had a tri-monitor mount in mind unfortunately
B bushbaby1234 Honorable Nov 17, 2012 36 0 10,540 Jul 18, 2014 Solution #2 I have 2 of these they look amazing next to each other. they great monitors in general. they are $150 normally but go on sale quite often http://www.newegg.com/Product/Product.aspx?Item=N82E16824009483&cm_re=h236_h236hl-_-24-009-483-_-Product they do NOT have a vesa mount if you had a tri-monitor mount in mind unfortunately Upvote 0 Downvote Solution
