Question Got a new case, too small looking for cooling ideas.
Feb 20, 2025
4
View: https://imgur.com/a/raHL6On
I’ve frankensteined my computer since forever and I finally got a new case, thing is it was a bit to small and I’m bad at saying no so I bought it anyways.
Now I ran some games for a few minutes and the CPU got to around 96 before I shut it off and GPU was about 86
I have my hdd and my sata under my gpu cause there’s no where else to put them.
I have to case fans but I’m not sure if they’re intake our out take but I figured you guys can tell me what to make each one.
Ryzen 5600 and rx6600
Thanks you very much in advance.
One, clean that heatsink. Two, clean up that cable management. Three, flip that top fan. It should be exhaust, not intake. It would probably help to know what case you even bought.
Sorry for the quick reply can’t play my pc right now so I’m just sitting here haha.
That’s true I should of gave it a good cleaning and then tested and posted!
I’m gonna get zip ties and an air gun tomorrow.
The case is golden field m3s
https://www.amazon.in/GOLDEN-FIELD-M3S-Computer-Aluminium/dp/B07FCDB31F
Well I re pasted my cpu, dusted everything, flipped the fan. But I’m I’m getting 90c on my cpu and gpu, might try the above picture and if not, get a new case then.
Well what case is this you are having problems?
In the first picture, the grey fan needs to be turned around, and a fan hole needs to be cut. But I need better pictures of this to give you a complete solution for it.
Also the I/o shield needs to be there, or tape the opening. Because air cooling requires pressure differences between the inside and outside of the case for it to work properly.
