Hi I have just recently upgraded and need help on connecting my GPU to the PSU. I have an EVGA GTX 980 with 6+6 pin and an EVGA G2 750W. The card came with two 6pin to molex adapters. I can plug these in and use a PERIF cable that has four molex splitters and a 6pin to connect into the PSU. My PSU has two 6+2 to 8 pin VGA connectors as well.
Do I use the VGA connectors or the PERIF one to connect the molex cables together?
Of note are the adapters that came with the GPU. The 6 pin connectors that go into the GPU look different, they have a middle pin in the top row that is missing. The 6+2 pin VGA ones have one filled in. Also the VGA cable go into two separate 8 pin holes in the PSU.
Does this difference matter?
