[SOLVED] GPU boot up problem
Sep 2, 2019
14
Basically, when i turn my pc my gpu starts spinning its fans, then stops and after that it turns on again and works totally fine afterwards. I just swapped my psu so i guess that has something to do with it. Is that part from the boot up sequence or is there a problem with my gpu/psu?
I want to point that this occurs only once when I am booting up the pc. Afterwards the gpu seems to work alright, even tried some games on it and it worked as good as always.
Latest posts
