Hello!
I have an Asus RTX 3060Ti Dual O8C that I bought in December 2020. It has been fine until about January - February when it started making some buzzing sounds.
At first, I thought it was the PSU, then coil whine, but what I found was that, even with no load, if I set the GPU fans to anything over 84%, the buzzing starts.
The temperatures seem fine and the performance is great. There doesn't seem to be a slower fan, although if it's just by a little bit, then I probably wouldn't have a way to find that out.
Specs:
CPU: AMD Ryzen 5 3600X,
GPU: Asus RTX 3060Ti Dual O8C,
RAM: 16GB DDR4 HyperX Predator (2x8GB),
Motherboard: Gigabyte B550M DSH3
PSU: Seasonic Focus-GX 80+ Gold 650W,
SSD M.2: ADATA XPG Gammix S11 Pro 256GB
SSD SATA: ADATA Ultimate SU650 480GB,
Case: Deepcool Macube 310P
Here is a recording I made while under load
Is this coil whine or a bad fan bearing or something else?
Specs:
