GPU cooler HELP !!!!
Milos-stancene
291
Hi
My sistem :
Q9550 2.8 @ 3.8Ghz
4x1 Gigs 800Mhz CL5
GTX 285 - 2048 Mb @http://www.alternate.at/html/solrSearch/toArticle.html?articleId=336302&query=Gainward+285&referer=detail&link=solrSearch%2Flisting.productDetails
Raptor
I wanna go to SLI but I need something to cool this two beasts ....
Any suggestions????
Thanx
Why ask for help for a problem that doesn't exist? As was said, stock cooler will be fine especially if you turn the fans up. Make sure you have good case airflow. What psu do you have?
I would not add another gtx 285 with that psu. It's just a mediocre quality and you'd be pushing it to it's limits with another card. You should get at least a Corsair 750W, and would be better off with a 850W.
I would not worry about it, I own the Asus p5q Pro and it only supports crossfire, not SLI, SLI is impossible on that board
