Question GPU Core clock speed stuck at 300 Mhz GTX 1660 Ti
Jan 2, 2021
Hello everyone! My laptop is Lenovo Legion Y540.
Regardless of the task I'm doing (whether I would play games or listening to music) my GPU Core speed is stuck at 300 Mhz (I should get around 1450 Mhz while playing games) which result in very low fps in games and low performance in 3D Mark.
https://www.3dmark.com/3dm/55921878 (I think you need to be logged in to see results)
I've reinstalled GPU and CPU drivers (to newest versions / to the ones Lenovo recommends), I've reset BIOS settings to default, nothing seem to work.
I am plugged in, my CPU doesn't have iGPU (i7-9750 HF).
https://drive.google.com/drive/folders/1FIBZPfXuzF3_3WhS97WRSjGstIBH2mCc?usp=sharing (Here you have link to my logs and screenshots from HWINFO).
Any idea what I can do?
Cheers everyone, happy new year!
PS. I know there were some threads about this problem here, but nothing I tried seemed to work.
Thanks so much for Your reply!
I'm not sure where I can check my power limits in gpu-z? If you mean "Board Power Draw" I can confirm that regardless if I'm idle or e.g. during benchmark max power draw looks to be around 170 W. The thing is, I tried and cannot change power limit eg. using MSI Afterburner.
