Hi im new here, just joined some min before
PC Specs
Mainboard: MSI X99 Godlike Gaming
CPU: I7 6900k @4,4ghz
GPU: ASUS Strix1080ti OC
RAM: G.Skill TridendZ RGB 3200MHz 32 GB DDR4
Windows 10 Pro
Yesterday my brother restarted my 2nd Pc (instead of shutdown was a simply missclick), then after he booted again, we shut them down normaly and today I turn him on and i got no picture...
Debug Codes shows that the mainboard is fully booted after restarting the PC (and resetting) error Code D6 was displayed an myself "Oh no" (Means no GPU Output detected)
So I removed the 1080ti and used my currently unused MSI Ventus 2080ti graphics card and then i got a picture.
After that i want just to be sure if the 1080ti was going broken over night and i put them into the 2nd pcie slot. So there was now the 2080ti on slot 1 and 1080ti on slot 2 after booting i looked inside all tools (Windows hardware manager, GPU_Z, ASUS GPU Tweak III) all detected the 1080ti fine... mhh oka
Then I tested the card and play some games with it and it works fine.
So after knowing that the card isnt broken i put them back in the first slot and just removed my 2080ti again. But again i got no piture also tryed diffrent outputs, restarting , resetting (DP , HDMI...) no way
then i just switched the 1080ti back to the 2nd slot and it works fine (even without the 2080ti)
Does anyone have an idea whats causing such strange things?? I just turned off the PC there was no update and so on... In past it happens sometimes that the PC needs servenal minutes until he can boot but that problem i have since i have this mainboart/plattform. But that happens ~1time per month but tody he just dont boot.
Maybe there is a simple solution or a logical explanation.
If someone need more infos just ask i try my best
PC Specs
Windows 10 Pro
