Hey here, last week my computer lost power very suddenly, which I then realised that my power plug on the walls power point was very loose which very likely caused the problem. I have then fixed it and tried rebooting the computer which did not work, computers fans and leds were lighting up like booting up normally for a half a second and then cutting off all the power suddenly. After this happening for once, I couldn't even see a single led turning on or fans moving for even a milisecond unless I cut off the power totally and plug it back in to have the exact result once again (computer tries booting for around half a second then turns off).
After a day I have realised a very different thing on my motherboard, one of my 4 rams was not perfectly settled in ( even though I used it like that for almost 2 years without a problem, which is very likely not even the problem but just a coincidence ). I have plugged off and on all the rams and then tried turning on the computer which did went very wrong.
I have seen few small sparks coming out of my GPU's top and smoke and a very heavy smell that many of you can imagine. I wasn't ready for this so I was maybe a little late turning off the power, which took me around 3-5 seconds. I was so curious about it so I actually tried booting the computer after plugging everything off and back on once again (which is obviously not a professional approach). And the result was quite similiar but this time the sparks was like blowing out around 5cm away from the GPU. After that happening I couldn't get the computer work at all with the GPU on.
I was already planning to get a new pc except the PSU and the case so I was able to be quite brave with trying it back to back. Wish I could get a video of that to share in here which I was planning to do but couldn't get the computer to work for the 3rd time with the GPU on.
My system specs is; GTX 960 ZOTAC 4gb, i5 4570, MSI Z87-G43 Military edition motherboard with 4x4 GB of ram and the PSU is the one that come out with my Cooler Master MB511 case which's name is as far as I have learned from what is says on it is; MPE-6501-ACABW 650W 80+ White.
Currently I can use my PC without any problem at all after plugging off my GPU totally and using the integrated graphics in the i5 cpu, which tells me that the motherboard or the PSU has no damage but im not sure.
After all that now I have a few questions in my mind to ask, some of them are just because of curiousity, some of them are more important so that I won't damage anything else.
1) Was the problem very likely caused by a short circiut happened after the power cut off which happened because of my power cable being very loose on the wall?
2) Is there any chance that any of my other computer parts including PSU, motherboard or any power cable is damaged?
3) Related to question 2, I bought a new GPU already as I was already planning before. The question is, should I give it a try on that motherboard? Any chance the motherboard can give any damage to my new GPU? I am very impatient to see my new GPU sitting on top of my desk doing nothing while I am using an integrated intel graphics, but of course, can't afford any damage to happen on my new GPU too .
4) Most importantly, any chance that my around 2 years old Cooler Master MPE-6501-ACABW 650W 80+ PSU is damaged? Cause I am not planning to change it at all and use it with my new GPU and the motherboard-cpu-ram combo which is supposed to be delivered in the upcoming days.
5) Is there any chance to repair the damaged GTX960 Zotac GPU?
I can provide even further information with the case. I have never experienced such a problem with any of my older GPU's.
