Question GPU fan % goes up, but rpm stays the same
Zotac 2070 super mini
GPU fans wont ramp up, they stay at 1200rpm at all times, even at full load and 87ºC
Manualy changing the speed at afterburner or any other app doesn't work.
Reinstaled the drivers, and did a fresh W11 instal, nothing worked.
Any ideas on how to solve it ?
CPU: i5-12400f
CPU cooler: Cooler Master T20
Motherboard: AsRock B660
Ram: 16GB T-Force Vulcan (2x8Gb) 3200mhz
SSD/HDD: Crucial P3 1Tb
GPU: Zotac RTX 2070 Super Mini
PSU: Azza 650W 3 Years Old
Chassis: Pichau Gadit X
OS: W11 23H2
Monitor: LG Ultragear 24' 1080p 144hz
When posting a thread of troubleshooting nature, it's customary to include your full system's specs. Please list the specs to your build like so:
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
include the age of the PSU apart from it's make and model. BIOS version for your motherboard at this moment of time.
Where did you source the installer for your OS? Did you install the OS in offline mode? Did you use DDU to remove all GPU drivers in Safe Mode?
CPU:
CPU cooler:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Monitor:
Hello! I filled in the info on the main post, thanks for the advice!
I did use DDU, instaled windows both from online and offline (Did it twice, one with each method*)
To add, i tested the gpu on a friends computer and the issue persisted.
