Hello everyone! First time poster, would like some help dealing with a recent issue I've been having.
My tech knowledge is very basic. Hope this is the right place and format to post in.
Specs:
Intel i7-9700K @ 3.6gHz
Asus Z390F Gaming Motherboard
2x8GB Corsair DDR4 Vengeance @RGB PRO 3200M
Zotac Gaming Geforce RTX 2080Ti 11GB
2xSSD Kingston A400 480GB (in RAID or whatever it's called)
Seagate Barracuda 2TB Sata3
NOX Hummer GD850 80plus GOLD
Liquid Cooling kit NOX Hummer H-240AURA RGB
Problem:
For the last month or so, I've been noticing a strange behaviour of one of the GPU fans. Basically, it will randomly start fanning at full speed (100%) for a few seconds, calm down, and then repeat it for a few seconds every 10 seconds or so. This symptom can be quite inconsistent.
If I play a low GPU load game or something easy, it wont happen at all. It only seems to start happening once the GPU is at max load and over 75 degrees (for example playing Anthem in 2k 144hz all maxed out or something like that). After a while, I can start max-fanning for 5-10 seconds every few seconds, meaning almost non stop, which is obviously troubling. I haven't changed my usage of the PC in any way in the last month at all. Furthermore, it is clearly only Fan number 1. The second one sometimes starts going max speed for a few rounds along with the other one, but it's quite rare. 90% of the time, it's Fan number 1 that's just going mental on it's own.
I hope I've explained it not to confusingly but please tell me if any info is missing! Here's a screenshot of that GPU-Z monitoring software that clearly shows the problem: look at Fan 1 Speed for the GPU and you can see all the pikes. This screenshot was taken in one of the worse moments of "overfanning". It was happening every 5 seconds. Pic: View: https://i.imgur.com/pjlDdwE.jpg
Thank you all in advance for your time!
Specs:
Problem:
