GPU Fan Making A Rattling Noise!
You may want to see if there's a cable/wire that might be brushing up against the fans at that speed. I've had instances where a stickered end of a cable would barely brush up against the fan blades producing an irritating noise/hum.
Might want to double check and post your full system's specs in case you're not running a bad PSU and it's not coil whine.
Could this be a result of gpu sag as it only occurs when the case is upright?
