Hello,
I've got a Zotac Twin Edge RTX 3070, where the big fan on the right stopped spinning.
Product Link:
Notes:
Thank you. ♥
Product Link:
Notes:
- It's fully clean, and you can't see any dust or anything 'visible' clogging it. - ( It was in a pc lifted wayyy above the floor)
- I've got 3x RTX 3070, all of them seems easy to spin! They all spin with Air blowers or your fingers EASY! But this fan (on the right) doesn't!
- The fan seems hard & slow to spin even with your finger, as if it's like glued almost, where other GPUs fans spin so easy!
- I never ran the fan more than 58-63c, never had it on 100% all the time neither.
- I monitor temps daily, i noticed it not spinning when I saw the temps rising to 70-80c & the fan still sits at 0%, where the one on the left is spinning.
- Warranty expired 🙁
- With everything I've said above, the way its very slow to spin even with your finger, does that mean I need to replace the fan or is there still hope?
- is there a way I can perhaps spray Lubricant Oil while its attached? - (As this GPU seems really hard to disassemble to get to fans that i'd rather not do it myself)
- When it's hard to spin even with your finger, is that a good sign that you can easily repair it, or is that a bad sign? 😕
Thank you. ♥
