Hey everyone. This is a recent problem i am having with windows 7, 7100 build. It started when i updated the nvidia driver to the most recent one, from nvidia's website and i got the driver for "windows 7 64-bit." Some info:
gpu = xfx gts 250
motherboard = abit ib9
windows 7 64bit, 7100 build
The Problem:
After windows starts, the fan is normal speed and you can not hear it. The temperature idles around 50c. When i start a game the temp starts increasing, and so does the fan speed. If you let the fan speed get up to full speed with the temp hovering around 75c, then close the game, the temp will drop to around 45c but the fan will stay at full speed. I have tried uninstalling the new driver and reinstalling a bunch of other drivers. I tried the one that came on the cd, ones straight from xfx's website, and slightly older versions from nvidia. Nothing helps. Also i already cleaned the gpu of dust.
Can anyone help me fix this problem? If more info is needed please tell me.
Thanks.
gpu = xfx gts 250
The Problem:
Thanks.
