yeah nothing wrong everything just "as new" i get even better fps 😉) they just start spinning at max and I can barely play any game from the sound 😉)Does the system still work fine? As fans ramping to 100% usually happens with my broken cards (of which I have a few), so I can start to help if the system is still fine.
Do you run MSI afterburner whilst gaming?yeah nothing wrong everything just "as new" i get even better fps 😉) they just start spinning at max and I can barely play any game from the sound 😉)
In reply to this, I re-read what you said, your card isn't loud, I use a 980ti FE, and she sounds like a damn plane, your card is what I wish for sound wise lol.Do you run MSI afterburner whilst gaming?
If i try to change the values for fan they wont change even if the afterburner is telling me that fans are 25% spinning 😉Do they spin to the maximum and then spin down, or are they at the maximum all the time?
If it's the former, nothing to worry about. It may be the system is doing some PCIe setup and it left the video card to its own devices for a moment. If it's the latter, I wouldn't consider it normal, but if you can use something like MSI Afterburner to set a fan curve, then there's at least a workaround.
No I dont play games with MSI but just to get the sound for example i play csgo with headset and i can play but if i play smth on speakers i need to turn up the volume to hear anything l😉)In reply to this, I re-read what you said, your card isn't loud, I use a 980ti FE, and she sounds like a damn plane, your card is what I wish for sound wise lol.
Are you sure the card might not just be quite loud, it's usual for some GPU's to be, download something like HW Monitor or the free version of AIDA64 and check the fan RPM and %If i try to change the values for fan they wont change even if the afterburner is telling me that fans are 25% spinning 😉
all sensors tell me the fan is at 0% and rpm 0Are you sure the card might not just be quite loud, it's usual for some GPU's to be, download something like HW Monitor or the free version of AIDA64 and check the fan RPM and %
Sounds like a busted sensor or fan controller thing on the video card.all sensors tell me the fan is at 0% and rpm 0
just look at this 😉)Sounds like a busted sensor or fan controller thing on the video card.
Can you check if the card has a 2, 3 pin or a 4pin connector for the fanjust look at this 😉)
View: https://imgur.com/a/xTx7uMZ
fans spinning at 100% and if i try to change the numbers change but fans still at 100%
yeah it has a 4 pin connectorCan you check if the card has a 2, 3 pin or a 4pin connector for the fan
Could be possible the fan is broken then or atleast it has had a sensor failureyeah it has a 4 pin connector
