So I have a Cooler Master K380.
I recently bought a Gigabyte GTX 1080 Windforce OC which is 280mm long, now according to the Specs of my K380 (http://assets.coolermaster.com/global/upload/product_feature/K380-ph1.jpg) it can fit up to 279mm in the current GPU slot. But it says at the bottom it can fit a 316mm card with no HDD.
I was wondering, How do I get my card in that position down there? Or will it fit nicely in the 279mm slot? And if it doesn't, does it require me to change stuff up with my power supply etc to get the slot down there? (I know I might have to swap some HDDs here and there for sure if it has to be down there)
I hope someone can help because this picture isn't quite enlightening me.
