GPU has 6 pin and 8 pin, PSU only has 8 pin
Feb 1, 2019
8
My GPU has slots for an 8 pin and 6 pin, but the PSU I ordered by mistake only has a 6+2 pin cable. Will it work with just the one at least temporarily or do I absolutely need a new PSU? My GPU is a Radeon R9 280 3gb, and this is the PSU I have:
https://m.newegg.com/products/N82E16817182295
It seems to be a decent PSU if a bit low on wattage. I’m guessing the answer is just to get a new PSU but I wanted to be sure.
Time for a new PSU that can support the card.
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully-Modular ATX Power Supply ($69.99 @ Newegg)
Total: $69.99
Generated by PCPartPicker 2019-02-05 17:34 EST-0500
or
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply ($39.99 @ Newegg)
Total: $39.99
Generated by PCPartPicker 2019-02-05 17:35 EST-0500
Ok, thank you for the replies. Out of curiosity what would happen if I did only use the one 8 pin? I’m not going to try it though, it’s not worth the risk. Also I may be upgrading to probably a RX 460 or similar, would those PSUs be enough to power that?
