[SOLVED] GPU load drops to 0% randomly
Sangeeth Sivan
67
Hi ,
So i have a 3700x and a ASUS TUF 5700 XT on ASUS TUF x570 Gaming Plus Motherboard. When playing Gears 5 on Recommended Settings ( Which is Ultra) . I experience major micro stuttering, i used raedon overlay to monitor it, and found out that my GPU UTIL is dropping to 0% from 90% sometimes , even from 60%. The temps are at 75-76 degree. Is it thermal throttling? i have a open air case. Core P3.
Any help would be appreciated. Thanks!
go to device manager
under system devices locate high precision event timer, right click it and disable it
open CMD or powershell with administrator rights
and type:
bcdedit /set disabledynamictick yes
press enter
then reboot
It seems your CPU is bottlenecking GPU. If your CPu is powerful enough, it should be PSU or the motherboard ($less probability)
Or your CPU might be undervolted which may cause problems
gpu wouldnt run zero from time to time, thats usualy some i/o issue
Ok so running latencymon in the background reported this issue.
View: https://imgur.com/a/ee7uhX4
uninstall your storage drivers, use microsoft drivers for now
open device manager -> ide ata/atapi controllers
right click on all controllers and click uninstall device and also mark up remove drivers
reboot is needed
Reactions: daPain58
reboot is needed
I have a Nvme SSD m.2 on my motherboard. Will uninstalling those drivers affect my system in any way?
