i have an asrock ab350m-hdv motherboard and i don't know how to remove the gpu. could someone help me?
I don't have this leverage. I do not know how to upload the photo are a kind of two lines connected at one end.Unscrew graphics card.
Find PCIE slot locking mechanism lever.
Push the lever to release lock.
Remove graphics card.
Upload to imgur.com and post link.I do not know how to upload the photo
View: https://imgur.com/a/K1qV9TtUpload to imgur.com and post link.
?? I don’t understandYou do have this leverage, as SkyNetRising showed with his picture. The flat black thing at the right end of the PCI-Slot
they are two different levers. I tried to pull right but it doesn't moveYou do have this leverage, as SkyNetRising showed with his picture. The flat black thing at the right end of the PCI-Slot
That lever could possibly be a plastic clip instead of a sliding lock. Try pushing the very end of the plastic up (towards the silkscreened "Front USB" words) while at the same time pulling the GPU out of the slot.
I know there is a bit of dust but put that the pc has been broken for 3 years I have never wanted to repair it and I think the time has come. however it has a problem that turns on the fans start but not from the video signal and starts the keyboard LEDs but not those of the mouse. now I was going to take him to show it. I wanted to remove the video card and start it to see if it was a problem with the power supply since I have never been able to remove it. I have already tested ram for ram, I tried to remove and put back the buffer battery and also ssd for ssd but nothing.That lever could possibly be a plastic clip instead of a sliding lock. Try pushing the very end of the plastic up (towards the silkscreened "Front USB" words) while at the same time pulling the GPU out of the slot.
Edit - Also, clean your CPU heatsink - it's clogged. 😉
Pull the lever up.they are two different levers. I tried to pull right but it doesn't move
