Recently I bought the XFX R9 280x. It has been fit correctly but my PC doesn't seem to connect with it properly. Its not the power supply because I have a 750w and that's more than enough, and the card itself is not faulty because it works with a friends PC. I thing it might be the motherboard though, I don't know if it is compatible, I should of checked that before I bought it.
Does anyone have any suggestions? thanks
Also, I cannot tell you what motherboard it is at the moment because my friend is trying to get it to work with my PC so I have to use an old laptop. 🙁
